The vestibule is a triangular space in the female vulva ( External genital organ) and there are 4 openings, these 4 initials are written in the VeStiBUle.
The trick to Learn: Openings In VeStiBUle - 4
V - Vaginal opening
S - Skene’s gland
B - Bartholin’s gland
U - Urethral opening
Trick to Learn: In SOS send SMS Please Transfer Some Money
S - Suboccipitobregmatic (9.5 cm)
O - Occipitofrontal (11.5 cm)
S - Suboccipitofrontal (10 cm)
S - Submentobregmatic (9.5 cm)
M - Mentovertical (13.5 cm / 14 c.m.)
S - Submentovertical (11.5 cm)
Please - BiParietal diameter (9.5 cm)
Transfer - BiTemporal diameter (8.2 cm)
Some - Super subparietal diameter (8.5cm)
Money - BiMastoid diameter (7.5 cm)
The trick to Learn: FORCEPS
F - Full dilatation of the cervix
O - Obtain the consent
R - Ruptured Membrane
C - Cephalic presentation engaged
E - Empty the bladder & bowel
P - Perform Episiotomy
S - Sedatives
The trick to Learn: REEDA
R - Redness
E - Edema
E - Ecchymosis (a discoloration of the skin resulting from bleeding underneath)
D - Discharge
A - Approximation (Approximation of wound edges)
The trick to Learn: Large - FEST
L - LH Surge
F - FSH Rise
E - Estrogen peak
S - Stretching factor
T - Theca externa’s micro muscle contraction
Events that start from number 4 in Obstetrics -
4 Parts of Uterus - Fundus, Body, Isthmus, Cervix
4 Parts of Fallopian tube – Intramural (interstitial), Isthmus, Ampulla, Infundibulum
4 Openings in Vestibule - Vaginal Opening, Skene’s Gland, Bartholin’s Gland, and Urethral Opening
4 Spermatids – After the completion of spermatogenesis 4 spermatids forms
4th day - Blastocyst enters into the uterine cavity
4 Visits in Pregnancy - According to WHO Total of 4 Antenatal visits needed
4 Types of Pelvis - Gynaecoid, Android, Anthropoid, Platypelloid
4 Leopold maneuvers (Obstetrical grips) – Fundal, Lateral (umbilical), Pawlik grip (2nd Pelvic grip), Pelvic grip (1st Pelvic grip)
4 Stages of Labour – Stages of Labour (1st, 2nd, 3rd, 4th)
4 Phases of Lactation - Mammogenesis, Lactogenesis, Galactokinesis, Galactopoiesis
4 Types of Placenta Praevia - Low Lying, Marginal, Partial central, Central
40 Weeks of Pregnancy - Duration of normal gestation (pregnancy) is about 280 days or 40 weeks
40 mg - daily iron requirement during pregnancy
400 μg - Daily folic acid requirement during pregnancy
400 Secondary Oocyte – Total no. of secondary Oocyte, a woman ovulate in her whole reproductive life.
Are you fed up with writing an article available? There are a lot of reasons why you want to save money and time by not doing this on yourself. However, most individuals don’t know how to do it properly. There are loads of people around who are willing to assist you, and supply quality advice to put you off the ground and onto the path towards achievement. We will provide you with a few suggestions about the best way best to write a personalized essay available which won’t only make you money, but also allow you to have fun masterpapers.com while finishing it. The tips below can help you avoid common essay pitfalls that you may run into.
